width of PML
What will be the width of the PML( circular) to determine the confinement loss in hexagonal pcf.
Regards
Md. Samiul Habib
6 Replies Last Post 5 feb 2013, 04:59 GMT-5
Posted: 1 decade ago 15 giu 2012, 04:51 GMT-4
I would say a few (<10) wavelength of air, then 2-3 for the PML distance. but I havent modelled optics and fibre for some time, others out here might have better rule of thumbs
Hi I would say a few (
Posted: 1 decade ago 15 giu 2012, 12:40 GMT-4
First, make PML very large. Then gradually decrease its thickness until your solution starts changing significantly. This way you can find an optimum that's right for you.
If you plan to solve for range of different wavelength, optimize PML for the largest wavelength
First, make PML very large. Then gradually decrease its thickness until your solution starts changing significantly. This way you can find an optimum that's right for you. If you plan to solve for range of different wavelength, optimize PML for the largest wavelength
Posted: 1 decade ago 16 giu 2012, 10:52 GMT-4
Thanx Ivar.
Thanx Ivar.
Posted: 1 decade ago 4 feb 2013, 09:27 GMT-5
how about number of layer ?
Posted: 1 decade ago 4 feb 2013, 19:52 GMT-5
I always use sweep mesh in PML with 3-5 layers. Again, you can increase the number of layers until you get the desired accuracy.
Posted: 1 decade ago 5 feb 2013, 04:59 GMT-5
According to Comsol Support answer I got, it does not matter. The PML will always be "one-wavelength" thick per default, you should just take care how you mesh it. They suggested using mapped-quadratic elements and make sure you have between 1-10 elements across the thickness of the PML. In my experience 4-6 usually is more than enough and I have never had any real need of 10 elements, the marginal computational accuracy vs. the time it takes to compute is not worth it.
Hope this helps
/RVN
According to Comsol Support answer I got, it does not matter. The PML will always be "one-wavelength" thick per default, you should just take care how you mesh it. They suggested using mapped-quadratic elements and make sure you have between 1-10 elements across the thickness of the PML. In my experience 4-6 usually is more than enough and I have never had any real need of 10 elements, the marginal computational accuracy vs. the time it takes to compute is not worth it. Hope this helps -- /RVN
