Replicating a work plane
I'm modelling a multi layer structure in which each layer is identical to the rest. I need to know a method so that I could replicate one work plane to the others without needing to build all the entities again and again to the subsequent work planes.
1 Reply Last Post 22 giu 2012, 06:15 GMT-4
Posted: 1 decade ago 22 giu 2012, 06:15 GMT-4
cant you replicate one object after the other, or use the layer feature in the 3D block or shape nodes (advanced tab)
Hi cant you replicate one object after the other, or use the layer feature in the 3D block or shape nodes (advanced tab) -- Good luck Ivar
