Save geometry
How can I save a geometry from model library? I am trying to practice COMSOL by doing model library, but I can't locate a file for geometry in order to import it. All I can do is to import the whole model which I don't want to. I just want to import the geometry. Please help me.
2 Replies Last Post 26 giu 2012, 13:39 GMT-4
Posted: 1 decade ago 20 giu 2012, 16:05 GMT-4
in v4.2 you had an export geometry in, I believe, the right click on the geometry node, but I do not know where it is in V4.3
Now usually the help or doc tells you sich things ;)
Hi in v4.2 you had an export geometry in, I believe, the right click on the geometry node, but I do not know where it is in V4.3 Now usually the help or doc tells you sich things ;) -- Good luck Ivar
Posted: 1 decade ago 26 giu 2012, 13:39 GMT-4
Thanks, I found it:)
