How to set up a simulation to run several times, the result of this operation as the initial value of the next operation
I am doing a physical simulation of heat transfer. I don’t know how to set the simulation to run several times. The initial condition of the next simulation is the result of the previous operation (the result of this operation is used as the initial value of the next operation), or how should I define The temperature of an object changes with time. I only set the temperature of the object in the 0th, 2nd and 4th seconds. The temperature of the object changes with the simulation process at other times, that is, it only changes at a certain point in time.
0 Replies Last Post 30 ott 2021, 05:10 GMT-4
Hello 坤 余
