mesh size
couple of times i came across a situation where the solution converge for bigger element size whereas it does'nt converge for a smaller element size.
how is this possible
1 Reply Last Post 12 lug 2012, 21:34 GMT-4
Posted: 1 decade ago 12 lug 2012, 21:34 GMT-4
it's possible if you setup something incorrectly. Then it's probably a coincidence that bigger mesh gives correct result. With the proper settings, solution should converge as you decrease mesh size.
another possibility is that the convergence is not monotonic. Again, by accident you hit the right spot with bigger mesh.
it's possible if you setup something incorrectly. Then it's probably a coincidence that bigger mesh gives correct result. With the proper settings, solution should converge as you decrease mesh size. another possibility is that the convergence is not monotonic. Again, by accident you hit the right spot with bigger mesh.
