time dependent solver related
I am using time-dependent solver for electrolysis process. Now I want to simulate it for 300 Secs. But in following manner ( i have written in syntax as we use in time stepping );
first : range(0, 0.0001, 0.001)
then in continuation second range(0.001, 0.001, 0.01),
then in continuation third range (0.01, 0.1, 10),
then in continuation forth range(10, 10, 300)
please advise me
2 Replies Last Post 23 apr 2014, 05:32 GMT-4
Posted: 1 decade ago 14 lug 2012, 12:08 GMT-4
what about trying something like:
{ range(0, 0.0001, 0.001) range(0.002, 0.001, 0.01) range(0.02, 0.1, 10) range(20, 10, 300) }
this should work, you must ensure the set is strictly increasing or decreasing
Hi what about trying something like: { range(0, 0.0001, 0.001) range(0.002, 0.001, 0.01) range(0.02, 0.1, 10) range(20, 10, 300) } this should work, you must ensure the set is strictly increasing or decreasing -- Good luck Ivar
Posted: 1 decade ago 23 apr 2014, 05:32 GMT-4
Dear Ivar,
I have a very similar, related question.
I also would like to have this explicit time step range. And in addition, I would like to repeat the sequence for a given amount of times, say n=3 times.
{0}
0*300 + { range(0.0001, 0.0001, 0.001) range(0.002, 0.001, 0.01) range(0.02, 0.1, 10) range(20, 10, 300) }
1*300 + { range(0.0001, 0.0001, 0.001) range(0.002, 0.001, 0.01) range(0.02, 0.1, 10) range(20, 10, 300) }
2*300 + { range(0.0001, 0.0001, 0.001) range(0.002, 0.001, 0.01) range(0.02, 0.1, 10) range(20, 10, 300) }
something like the above. But then that also Comsol understands it.
Can you advise me on how to program this?
Many thanks in advance
Erica
Dear Ivar, I have a very similar, related question. I also would like to have this explicit time step range. And in addition, I would like to repeat the sequence for a given amount of times, say n=3 times. {0} 0*300 + { range(0.0001, 0.0001, 0.001) range(0.002, 0.001, 0.01) range(0.02, 0.1, 10) range(20, 10, 300) } 1*300 + { range(0.0001, 0.0001, 0.001) range(0.002, 0.001, 0.01) range(0.02, 0.1, 10) range(20, 10, 300) } 2*300 + { range(0.0001, 0.0001, 0.001) range(0.002, 0.001, 0.01) range(0.02, 0.1, 10) range(20, 10, 300) } something like the above. But then that also Comsol understands it. Can you advise me on how to program this? Many thanks in advance Erica
