depth in 2D fluid structure interaction
Posted 7 set 2012, 14:14 GMT-4 MEMS & Nanotechnology, Fluid & Heat, MEMS & Piezoelectric Devices, Microfluidics, Geometry, Structural Mechanics Version 4.3 1 Reply
Hi all-
I am trying to model a microvalve using a 2D fluid structure interaction interface. The models seems to run just fine, but all of my displacements are off, as there doesn't seem to be a way to define the depth (into the plane) of the structures. When using the solid mechanics interface, this option is available, but I can't find it in the fsi interface.
It appears that the interface assumed a 1m depth, and the result is that the stiffness of the structures is off by several orders of magnitude.
Has anyone else figured out a way around this?
Thanks!
Kamala
Thanks!
Kamala
1 Reply Last Post 7 set 2012, 16:14 GMT-4
