Need help: Error whenever trying to simulate periodic boundary condition in RF module
Hi Everybody,
I'm trying to do 3D RF module simulation with periodic boundary condition on the sides. Every time i start the computation, i keep getting an error that says :
Unknown function or operator.
- Name: mod1.emw.dst2src_pc1
I guess this error is related to the periodic boundary condition as when i run it with perfect conductor boundaries it works fine. Does this mean my comsol do not have this function or something?
Thanks in advance for any assistance / suggestion
3 Replies Last Post 21 dic 2012, 16:14 GMT-5
Hello Aimi Abass
Posted: 1 decade ago 5 dic 2012, 16:58 GMT-5
I am getting the same error. Have you solved the problem?
Hi, I am getting the same error. Have you solved the problem?
Andrea Ferrario COMSOL Employee
Posted: 1 decade ago 6 dic 2012, 09:37 GMT-5
Aimi, Hossein,
The error is probably caused by an incorrect setup. See the model fresnel_equations in the Model Library, RF Module -> Verification Models for a simple example on how to setup boundary conditions.
If you still experience the same error (in version 4.3a), please send the problematic model to support ( www.comsol.com/support/case/ ) adding a reference to this thread.
Andrea Ferrario
Electromagnetics Group
COMSOL AB
Aimi, Hossein, The error is probably caused by an incorrect setup. See the model fresnel_equations in the Model Library, RF Module -> Verification Models for a simple example on how to setup boundary conditions. If you still experience the same error (in version 4.3a), please send the problematic model to support ( http://www.comsol.com/support/case/ ) adding a reference to this thread. -- Andrea Ferrario Electromagnetics Group COMSOL AB
Posted: 1 decade ago 21 dic 2012, 16:14 GMT-5
Aimi, Hossein,
Andrea Ferrario
COMSOL AB
Thanks Andera,
The problem solved... the error happens after having more than 2 surfaces on a single PBC, type Floquet. So, to have periodicity in 2 dimentions, there are two PBCs needed, one for X and another for Y.
Good Luck
[QUOTE] Aimi, Hossein, The error is probably caused by an incorrect setup. See the model fresnel_equations in the Model Library, RF Module -> Verification Models for a simple example on how to setup boundary conditions. If you still experience the same error (in version 4.3a), please send the problematic model to support ( http://www.comsol.com/support/case/ ) adding a reference to this thread. -- Andrea Ferrario Electromagnetics Group COMSOL AB [/QUOTE] Thanks Andera, The problem solved... the error happens after having more than 2 surfaces on a single PBC, type Floquet. So, to have periodicity in 2 dimentions, there are two PBCs needed, one for X and another for Y. Good Luck
