Confusing error message for: Rollers on a beam.
Hey,
I am creating a model of how a bone will react under different loads from a 4-point bending. The model has been created as a 2D model where the geometry and material properties are set to that of the bone, and the model works when the ends are fixed constraints. I am solving the problem in solid mechanics as a stationery study where the solution is solved using a parametric sweep.
However, I want to change the fixed constraints to roller, as I am validating the model using a 4-pont bending in a lab where the moulded ends are on rollers. When I set the ends of the rectangle to be on rollers in comsol the following error message appear:
Feature: Stationary Solver 1 (soll/s1) Failed to find a solution. The relative residual (0.0093) is greater than the relative tolerance. There was a warning message from the linear solver. Iterative refinement triggered. The returned solution is not converged. Not all parameter steps returned.
Does anyone know how I can solve this problem? I have attached the model below and am hoping someone could explain how to fix it.
Thank you in advance!
3 Replies Last Post 12 dic 2022, 11:28 GMT-5
Kristian Rye Jensen COMSOL Employee
Posted: 2 years ago 7 dic 2022, 05:25 GMT-5
Dear Amber Labuz,
Thank you for posting on the Discussion Forum.
When you have a roller condition instead of a fixed condition and you have a load, there are nothing to stop the movement, so it will go on indefinitely in the y-direction.
There will be an infinity of solutions, that's why it doesn't converge.
If you have further questions, you can use the technical support through support@comsol.com.
Hope this helps.
Kristian Rye Jensen
Kristian Rye Jensen
COMSOL DK
Dear Amber Labuz, Thank you for posting on the Discussion Forum. When you have a roller condition instead of a fixed condition and you have a load, there are nothing to stop the movement, so it will go on indefinitely in the y-direction. There will be an infinity of solutions, that's why it doesn't converge. If you have further questions, you can use the technical support through support@comsol.com. Hope this helps. Best regards, Kristian Rye Jensen
Posted: 2 years ago 12 dic 2022, 11:19 GMT-5
Hey Kristian,
Thank you for the reply, i have tried contacting the support email but have not gotten any reply. Is there another way i can add mechincal support rollers onto my model?
Best Amber
Hey Kristian, Thank you for the reply, i have tried contacting the support email but have not gotten any reply. Is there another way i can add mechincal support rollers onto my model? Best Amber
Posted: 2 years ago 12 dic 2022, 11:28 GMT-5
Hello Amber,
The support team sent you a response on December 9 (three days ago). Please check your Access account / email.
Jeff Hiller
Hello Amber, The support team sent you a response on December 9 (three days ago). Please check your Access account / email. Best, Jeff
