Counter_driven_ coils
I'm new to COMSOL and I'm trying to model the b-field lines of a copper coil matrix and its interactions with an inert copper plate. I've been able to build a geometry and mesh however I've confused on how to "power" the coils. I want to have the coils counter driven in a lattice fashion using an 8[Mhz] sine wave I've tries the RF module and the circuit model but to no avail . Anyone have some insights?
I've also attached what i have to to help anyone visualize
regards
4 Replies Last Post 1 nov 2012, 03:07 GMT-4
Posted: 1 decade ago 29 ott 2012, 16:18 GMT-4
apologies, the model was too large to attach
Posted: 1 decade ago 30 ott 2012, 02:24 GMT-4
you should "clean up your model" before attaching them on the forum, we wold need to resolve, but that is often easier.
To clean; select Edit - Clear all solutions, Clear all mesh, File - Reset history, and Save as with new name, then upload
Hi you should "clean up your model" before attaching them on the forum, we wold need to resolve, but that is often easier. To clean; select Edit - Clear all solutions, Clear all mesh, File - Reset history, and Save as with new name, then upload -- Good luck Ivar
Posted: 1 decade ago 31 ott 2012, 21:20 GMT-4
Ivar,
Even with your memory reducing steps I wasn't able to fit the whole model. However I was able to reduce it and now it fits, the only difference is the number of turns per coil. Hopefully now you will now be able to help me.
Regards
Eric
Ivar, Even with your memory reducing steps I wasn't able to fit the whole model. However I was able to reduce it and now it fits, the only difference is the number of turns per coil. Hopefully now you will now be able to help me. Regards Eric
Posted: 1 decade ago 1 nov 2012, 03:07 GMT-4
COMSOL has also "lumped" coil BC's that consider also multiturn coils, you do not get the details of the coil winding interiour, but you model solves often easier. Nevertheless, these BC's are complex physics, so read carefully the doc and try a few exercices befor using them, to really understand how they work
Hi COMSOL has also "lumped" coil BC's that consider also multiturn coils, you do not get the details of the coil winding interiour, but you model solves often easier. Nevertheless, these BC's are complex physics, so read carefully the doc and try a few exercices befor using them, to really understand how they work -- Good luck Ivar
