2 decades ago
19 feb 2010, 11:57 GMT-5
basically you can do whatever you want with the equations under Physics Equation Systems Subdomain Settings Variables Pan
The only thing/caveat is that if you modify something such as the sx_... variables, your domain will be flagged with a keylock which indicating that COMSOL willnot and cannot update this domain as COMSOL is not programmed to understand what is going on when you change your physics this way.
So that, if you add some new physics, variables might not follow or be updated correctly.
You can always backtrack by hitting the Reset Equation
From thereon I'll leave it to you to update your physics, because I'm not sure I understand correctly what exactly you want to do, so I do not think I can help much further.
In anycase good luck, with COMSOL we are back doing physics, finally
2 decades ago
9 apr 2010, 10:26 GMT-4
Dear Ivar,
I am also manipulating the Physics Equations System -Subdomain Setting.
In my case, I do change the way stress is calculated. Instead of the linear Hookian Stress-Strain relation, I do use Anand's relation. Therefore I do introduce a new variable for the strain e_ij in addition to the linear-elastic Hookian strain. To calculate the stress, I do subtract the Anand-strain from the corresponding sx=E_smps*(ex_...-ex_anand)...
Basically the same idea as used in "Viscoplastic Creep in Solder Joints" Model ID: 4488.
Can you help me to understand how the variable sx_... flagged with a keylock does effect the computation? I am not sure, what is meant by updating a domain, and whether this affects my transient simulation of creep. Do you know some sources for further reading?
Stefan Wolf
Dear Ivar,
Stefan Wolf
2 decades ago
9 apr 2010, 11:08 GMT-4
The only thing I know is that the "lock" is there when you change the equations directly in such a way that COMSOL cannot understand it anymore. Because, when you change modes, physics etc, COMSOL updates the equations, but it does not touch "locked" equations because that's "your" responsability.
But I'm not sure how COMSOL flags any warning if it wants to change soemthing that you have locked, you might have some surprises such as expecting COMSOL to update something but this is NOT done as the equations are locked.
I have a couple of examples of locked equations too (the last one is the most up to date) in the paralle thread where I have dumped some of my thought/tests about torque loads and rotation restraints in solid structural. the example is 2 but protable to 3D. look carefully through loads and the physics equations as there are several "locks" in there on boundaries and on points
www.comsol.com/community/forums/general/thread/3566/#p11777
http://www.comsol.com/community/forums/general/thread/3566/#p11777
