Projection of an Isosurface onto a plane or boundary
Hello
Another visualization question: Is it possible to plot the projection of an Isosurface in 3D space onto a 2D surface or plane (such as the x-y plane).
Thanks in advance
Dan
2 Replies Last Post 7 dic 2012, 00:54 GMT-5
Posted: 1 decade ago 5 dic 2012, 01:10 GMT-5
isn't that "just" to make a "data set" cut plane and plot a contour plot on the cut plane ?
Hi isn't that "just" to make a "data set" cut plane and plot a contour plot on the cut plane ? -- Good luck Ivar
Posted: 1 decade ago 7 dic 2012, 00:54 GMT-5
Hi Ivar
I may have misunderstood but what you are suggesting seems to be to take a cross section of the isosurface and then plot a contour line which isn't exactly what I want to do.
The aim is to plot the 'outline' of the whole isosurface from the aspect (or view) of one of the planes (e.g yz plane).
Do you think it's possible?
Thanks for helping
Dan
Hi Ivar I may have misunderstood but what you are suggesting seems to be to take a cross section of the isosurface and then plot a contour line which isn't exactly what I want to do. The aim is to plot the 'outline' of the whole isosurface from the aspect (or view) of one of the planes (e.g yz plane). Do you think it's possible? Thanks for helping Dan
