help me. _ failed to find consistent initial values Error~
hello,
I use the comsol multiphysics 3.5a
I am having difficulty comsol to converge on time dependent solutions.
Recently i happened the error i can not understand
Error:
Failed to find consistent initial valuses.
I have attached the model file and some of fictures.
please check the my model file.
first I succesed the transient initialization of two phase flow, phase field
then i tried to transient but happened the error
on the fifth line from the top of the message.
So i thick that i had not defined enough variables, and incorrect geometry, boundary conditions
I checked theirs but did not find out error factors.
I have one more question.
iI take a fluid load on the solid part at the boundary settings of plane strain
but fluid load unit is red on the Load tab
why unit(N/m^2) shows red at the Load tab
Please help me
Also, which method will be best?
Help will be most appreciated,
I will wait for you.
0 Replies Last Post 22 feb 2010, 06:46 GMT-5
Hello Seo Wonsang
