Simulating 2D optical waveguide
I am simulating a 2D optical waveguide for both TE and TM modes.
For TE waves I get reasonable result by setting the cladding core interface as perfect electric conductor.
I use excitation port with analytic mode and exist port also as analytic mode.
However, for TM modes I do not get a reasonable result (please see attached file).
I've switched the core-cladding interface to be perfect magnetic conductor.
Any comments will be helpful. Thanks.
3 Replies Last Post 11 ott 2016, 08:31 GMT-4
Hello David964
Posted: 9 years ago 20 mag 2016, 11:32 GMT-4
HELLO DAVID
in ur model u have not shown cladding.....only core is there.
what diameter off cladding u r taking...send me ur model.....i will guide you.
waiting for ur reply
HELLO DAVID in ur model u have not shown cladding.....only core is there. what diameter off cladding u r taking...send me ur model.....i will guide you. waiting for ur reply
Walter Frei COMSOL Employee
Posted: 9 years ago 20 mag 2016, 11:38 GMT-4
Regarding optical waveguide modeling in the full-wave regime, please see the following example:
www.comsol.com/model/dielectric-slab-waveguide-14709
You may also be interested in the beam-envelopes formulation, as shown here:
www.comsol.com/model/mach-zehnder-modulator-15061
www.comsol.com/model/optical-ring-resonator-notch-filter-22221
Hello, Regarding optical waveguide modeling in the full-wave regime, please see the following example: https://www.comsol.com/model/dielectric-slab-waveguide-14709 You may also be interested in the beam-envelopes formulation, as shown here: https://www.comsol.com/model/mach-zehnder-modulator-15061 https://www.comsol.com/model/optical-ring-resonator-notch-filter-22221
Posted: 8 years ago 11 ott 2016, 08:31 GMT-4
I am trying to simulate the same model as you have attached before the Notch Filter, but I am trying to determine the parameters of the radius and the distance for other materials, I am doing a parametric sweep in the radius and in the distance between the waveguide and the microring resonator, and the problem appears when I try to plot the transmission in a surface plot with this two parameters.
Could you help me, please?
Often appears the next message:
No solution found for outer solution number 1000.
Hello, I am trying to simulate the same model as you have attached before the Notch Filter, but I am trying to determine the parameters of the radius and the distance for other materials, I am doing a parametric sweep in the radius and in the distance between the waveguide and the microring resonator, and the problem appears when I try to plot the transmission in a surface plot with this two parameters. Could you help me, please? Often appears the next message: No solution found for outer solution number 1000.
