script for exporting deformed geom from livlink matlab ?
Hi all,
In GUI, I could remesh the deformed configuration from the results dataset, and from there i could export to a new geometry (xx.mphbin). But how can i do the same from matlab livelink ?
I wrote, "model.result.dataset('dset3').createDeformedConfig('deform1', 'mesh2');", but what could be the next lines in the script for exporting to a new geometry file ? Of course I tried to do it from GUI and then save model as m-file to see the script for exporting, but it didn't show anything equivalent java or matlab command for 'exporting to file' action.
Any help is appreciated ! Thanks.
/Krishna
4 Replies Last Post 15 nov 2016, 06:07 GMT-5
Hello Krishna Manda
Posted: 1 decade ago 14 apr 2014, 20:03 GMT-4
Hi all,
/Krishna
I have the same question, does anyone in this community know about this matlab script?
Appreciate your help~~
[QUOTE] Hi all, In GUI, I could remesh the deformed configuration from the results dataset, and from there i could export to a new geometry (xx.mphbin). But how can i do the same from matlab livelink ? I wrote, "model.result.dataset('dset3').createDeformedConfig('deform1', 'mesh2');", but what could be the next lines in the script for exporting to a new geometry file ? Of course I tried to do it from GUI and then save model as m-file to see the script for exporting, but it didn't show anything equivalent java or matlab command for 'exporting to file' action. Any help is appreciated ! Thanks. /Krishna [/QUOTE] I have the same question, does anyone in this community know about this matlab script? Appreciate your help~~
Posted: 9 years ago 19 set 2015, 15:20 GMT-4
www.comsol.com/community/forums/livelink-products/thread/62831/#p206493
My answer in another thread
https://www.comsol.com/community/forums/livelink-products/thread/62831/#p206493 My answer in another thread
Posted: 9 years ago 22 set 2015, 03:38 GMT-4
This should work:
model.result.dataset('dset1').createDeformedConfig('deform1', 'mesh2');
model.geom('deform1').export('newgeomfilename');
Lars Gregersen
Comsol Denmark
Hi This should work: model.result.dataset('dset1').createDeformedConfig('deform1', 'mesh2'); model.geom('deform1').export('newgeomfilename'); -- Lars Gregersen Comsol Denmark
Posted: 8 years ago 15 nov 2016, 06:07 GMT-5
thank you
Nicolas LE CORVEC, PhD
Planetary Volcanologist - Postdoctoral Fellow
ClerVolc, the Clermont-Ferrand Centre for Volcano Research
Laboratoire Magmas et Volcans
thank you -- Nicolas LE CORVEC, PhD Planetary Volcanologist - Postdoctoral Fellow ClerVolc, the Clermont-Ferrand Centre for Volcano Research Laboratoire Magmas et Volcans
