Parametric Sweep
Can I know how to use parametric sweep??
1 Reply Last Post 25 mar 2013, 08:16 GMT-4
Posted: 1 decade ago 25 mar 2013, 08:16 GMT-4
it has been discussed a dozen time on the Forum, and it's rather well described in the doc and examples, try a search:
Note that you have 2 types: the continuation type, one model you vary a parameter inside of some physics but your geometry is not changing, and the "external one when you loop around the full geometry and re-meshing as the parameters changes the geometry
There are hence 2 ways to select or add parameter-sweep nodes
Hi it has been discussed a dozen time on the Forum, and it's rather well described in the doc and examples, try a search: Note that you have 2 types: the continuation type, one model you vary a parameter inside of some physics but your geometry is not changing, and the "external one when you loop around the full geometry and re-meshing as the parameters changes the geometry There are hence 2 ways to select or add parameter-sweep nodes -- Good luck Ivar
