30 mar 2013, 08:26 CET
do you mean you have an alloy or a mixture of liquids ? THis can be done but COMSOL does not know how this mixture behaves. For chemistry and liquids you have special 2 (or more?) species physics check the doc.
But for i.e. solid its trickier as i.e. mixing iron and nickel gives you many "different" materials all depending on ratio temperature history ... and with very different material properties such as E, nu, rho, alpha(T) ...
30 mar 2013, 09:51 CET
But the moist air mixture is known for Comsol, but when it is used, so the solver fails and writes an error or not complete the calculation.
Similarly, if we use a porous material in AC / DC solver writes a mistake without me set other inputs.
Thank you.
Thank you.
30 mar 2013, 11:54 CET
true COMSOL has added the moist air mixture lately, that is handy.
But so far I haven't seen any error with it, so you need to upload you models for us out here to be more specific, like that it's too vague and I do not know what to answer ;)
30 mar 2013, 15:31 CET
Hey.
Tray this:
1.in new models give rectangle, ac \ dc \ mf (magnetic field)
2.A mf open Ampers Law and forth to adjust the part of the magnetic permeability
poros material
3.click study compute
and send me a reply or error.
part of the amount of porous material I enter 0.4.
Thank you very much.
Hey.
Tray this:
poros material
3 apr 2013, 22:58 CEST
but if you have a porous media you need at least 2 materials (applied to the same domain, no?)
Check the doc/help the Porous node requires some settings and the sum of porosities should sum up to 1
