Piezoelectric Device 3D
Manu Goiogana Bengoetxea
I'm a quite new user in Comsol, and I have some doubts about the Piezoelectric Devices (pzd) Module.
I have built a model with 2 ceramic rings (see the model in the attached file), that are suposed to create an axial vibration to the transducer. In order to obtain that, the two ceramic rings are polarized in the opposite directions. Hower, the result is not what I am looking for.
I have tried polarizing the ceramics in different ways, but no way.
It is suposed that the axial vibration created with the first ceramic added to the vibration createeed with the second, the effect is going to be double, and then, this is going to be transmited to the elastic cylinders coupled.
How would you define the coupling in this case? I am not sure if I have to use a pair in this case or not.
Any help to solve this strange result will be very grateful
Thanks a lot
3 Replies Last Post 22 apr 2016, 06:53 GMT-4
Posted: 1 decade ago 5 apr 2013, 15:06 GMT-4
in 3D there are many things to get right, and with a complex physics like PZD even more.
I can only suggest that you start with the two PZT cylinders without the rest. Make them by 1 part with a central layer in the middle. Then add 2 PZT physics nodes and orient the PZT items accordingly (if you do not want them co-linear as you polarize them with a mirror plane with GND outwards. Thest thes out with a coarse mesh, so they solve in a few seconds, and play around until you are sure you mater the coordinate projections ...
Hi in 3D there are many things to get right, and with a complex physics like PZD even more. I can only suggest that you start with the two PZT cylinders without the rest. Make them by 1 part with a central layer in the middle. Then add 2 PZT physics nodes and orient the PZT items accordingly (if you do not want them co-linear as you polarize them with a mirror plane with GND outwards. Thest thes out with a coarse mesh, so they solve in a few seconds, and play around until you are sure you mater the coordinate projections ... -- Good luck Ivar
Posted: 10 years ago 4 mar 2015, 04:14 GMT-5
I am working on a ring shaped piezoelectric transducer in free field. I have successfully built this in a 3D model that works, which is attached. I am encountering a issues with total surface displacement of piezo. As my intention to built this model is piezo transducer displacement in a axial direction at its resonance frequency which displaced maximum on top, bottom of the piezo ring and minimum at center of the ring. But in my model shows that the piezo transducer displacement in radial direction at its resonance frequency. can any one help me with some suggestions
Posted: 9 years ago 22 apr 2016, 06:53 GMT-4
Hello , I currently looking for how to simulate the tension resulting applying pressure on a piezoelectric beam using COMSOL , I need help and thank you !
