Propagation of white light
Thomas Andrews Joseph
I want to study propagation of broadband light through optical fiber. Iis there any option in Comsol that could do spectral analysis?
THOMAS
1 Reply Last Post 5 mar 2010, 09:07 GMT-5
Posted: 1 decade ago 5 mar 2010, 09:07 GMT-5
the way I see it is to run a parametical sweep of the wavelength covering the "white light spectrum" but then you get an "harmonic" or spectral view,
then how to correctly "mix" these wavlength results to get a global result will depend on what you are looking for
good luck
Hi the way I see it is to run a parametical sweep of the wavelength covering the "white light spectrum" but then you get an "harmonic" or spectral view, then how to correctly "mix" these wavlength results to get a global result will depend on what you are looking for good luck Ivar
