Cylinder section modelling
Hello all
I wish to model structural mechanics in a section of a cylinder-like geometry consisting of longitudinal bars and radial rigid hoops supporting the bars. The full cylinder is too memory intensive to model an so I have drawn a section of the cylinder only. My question is: what contraints should be used on the end of the hoop sections to simulate the fact that they form a closed loop. I have tried a number of fixed constriants and prescribed displacement conditions but they do not result in reasonable solutions.
Any ideas?
Thanks a lot
Dan
2 Replies Last Post 8 mag 2013, 22:36 GMT-4
Posted: 1 decade ago 3 mag 2013, 00:47 GMT-4
do you have 2D-axi symmetry ? so you could use a simple section and 2D-axi ?
or have you tried to consider beam and/or truss elements, perhaps with shells ? that highly simplifies the geometry and meshing incl DoF's
Hi do you have 2D-axi symmetry ? so you could use a simple section and 2D-axi ? or have you tried to consider beam and/or truss elements, perhaps with shells ? that highly simplifies the geometry and meshing incl DoF's -- Good luck Ivar
Posted: 1 decade ago 8 mag 2013, 22:36 GMT-4
Hi Ivar
Thanks so much for your suggestions. I don't have 2D axi symmetry but the beam/truss/shells approach seems like an excellent idea. I will run with that.
Thanks again
Dan
Hi Ivar Thanks so much for your suggestions. I don't have 2D axi symmetry but the beam/truss/shells approach seems like an excellent idea. I will run with that. Thanks again Dan
