Solving multiple modules simultaneously.
Posted 29 mag 2013, 13:12 GMT-4 MEMS & Nanotechnology, MEMS & Piezoelectric Devices, Microfluidics Version 3.5a 1 Reply
One module is a partial differential equation in place of electrostatics to simulate an electric field being generated by 2 electrodes and the second is heat transfer via conduction in the solution on top of the electrodes. The problem is that the voltage applied is the source of heat generation so the second module requires it but at the same time, variables such as conductivity and permittivity are temperature dependent.
I have tried solving them together using an initial Temperature but the program results in a failure almost immediately due not being able to solve for variables such as voltage.
Any advice on how to proceed would be greatly appreciated.
Hello Joshua Raveendran
