Doubt with extrusion coupling
Posted 6 ago 2013, 05:59 GMT-4 Parameters, Variables, & Functions 0 Replies
I have been reading the documentation on extrusion coupling and the packed bed reactor example in which extrusion coupling is used.
I have a couple of questions:
1) How to select the destination map: do you have, in essence, to "convert" both lines to a single length? (multiply/ divide x as appropriated)?
2) I assume that the extruded variable would be continuously defined in the new domain. Does it catch the dependency with the new space dimension?
Thanks in advance
Hello brc
