Simple heat module problem
Posted 19 set 2013, 08:48 GMT-4 Heat Transfer & Phase Change, Studies & Solvers Version 4.3b 2 Replies
I have been using COMSOL for a while now, but this is the first time I have had to use the heat transfer module. I could attach my model, but I feel the problem is simple enough not to require it. I have set a temperature to a certain surface which is in contact with another with a given starting temperature. I merely wish to plot the energy flux through the contacting surface as a function of time. As of yet, I have not found of a way to do this. Any help would be greatly appreciated.
Thank you,
Peter
Thank you,
Peter
2 Replies Last Post 23 set 2013, 06:20 GMT-4
