Confused on modeling thermal expansion in a plastic block
I am new to Comsol and trying to model the thermal expansion of a small plastic cube on a post. I was hoping this would be simple to model, but I am having trouble getting the expansion to act correctly. Hopefully someone can help me troubleshoot this, because I am at a loss.
I am heating and cooling a plastic cube (1cm length/width/height) from one side from -55 degC to 85 degC and I am interested in looking at the total expansion in the x and z directions. I used the "Thermal Stress" module available in Comsol 4.3b to attempt to model this.
Each time I run the program with different thermal expansion coefficients or different temperatures, it still gives me a 1mm expansion in each direction. It's as if the parameters I entered do not influence what the program is calculating for the expansion. On paper, I calculated that the total expansion when heated from room temp (~25degC) to 85degC is roughly 50um, so the 1mm that Comsol is calculating is much too high.
If you have any thoughts, I would greatly appreciate it. I have been struggling with this for days now.
Thanks!
Jessica
3 Replies Last Post 9 ott 2013, 11:24 GMT-4
Posted: 1 decade ago 8 ott 2013, 17:31 GMT-4
Hello Jessica,
When plotting the deformed shape in a structural analysis, COMSOL uses a scaling factor to exaggerate the deformations so they are visible to the naked eye. Perhaps this is what's leading you to believe that the displacements are larger than they actually are. Just a guess.
Hello Jessica, When plotting the deformed shape in a structural analysis, COMSOL uses a scaling factor to exaggerate the deformations so they are visible to the naked eye. Perhaps this is what's leading you to believe that the displacements are larger than they actually are. Just a guess. Jeff
Posted: 1 decade ago 9 ott 2013, 07:48 GMT-4
Hi Jeff, and thank you for replying. I had not thought of that idea. That does make sense though. Do you know if there a way for me to calculate what the actual expansion is in Comsol even if it is exaggerating the results?
Posted: 1 decade ago 9 ott 2013, 11:24 GMT-4
You could do a surface (or volume) plot of the displacements for instance. The min and max values will then be indicated on the colorbar.
The Reference Manual has extensive information on the many postprocessing options available. You can access that manual through the Help menu.
You could do a surface (or volume) plot of the displacements for instance. The min and max values will then be indicated on the colorbar. The Reference Manual has extensive information on the many postprocessing options available. You can access that manual through the Help menu. Jeff
