PID with constraints
Hi All,
I have implemented a PID temperature controller in my model that controls the voltage applied to a resistive heater to achieve a set temperature. However the PID algorithm achieves this setpoint by applying voltages outside of whats practical for my system to achieve the shortest rise time.
I want to know how to constrain my voltage applied so that it only solves for and applies voltages within practical limits say V_ctrl<20. I tried using a global constraint in the ODE interface but it does not constrain the voltage.
Thanks in advance for your help.
Alex
2 Replies Last Post 7 nov 2013, 14:06 GMT-5
Posted: 1 decade ago 7 nov 2013, 13:21 GMT-5
Alex,
difficult to give an advice without knowing anything about your implementation. In a PID controller the control variable depends on the P, I and D parameters. But as you implemented the thing I am sure you know that. Are you using the I and D parameters? Particularly D can be tricky.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Alex, difficult to give an advice without knowing anything about your implementation. In a PID controller the control variable depends on the P, I and D parameters. But as you implemented the thing I am sure you know that. Are you using the I and D parameters? Particularly D can be tricky. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 7 nov 2013, 14:06 GMT-5
Thanks for the reply Edgar.
Yes I just needed to do some more tuning to get my control variable where it needed to be.
Thanks for the reply Edgar. Yes I just needed to do some more tuning to get my control variable where it needed to be.
