java exception error in using postcrossplot code.....
I am working in windows xp os and with Comsol 3.5a with matlab R2008b
I am exporting model file form comsol to matlab as fem and is saved in fem file in workspace. when iam using postcrossplot in order to save it and use it for meshintegrate code for integration on a particular cross section in a domain.
but when iam using code postcrossplot in matlab command window as follows
pd = postcrossplot(fem,2,[0.015 0 0;0.015 0 0.03;0 0.015 0]','surfdata','T')
extracting temperature data from subdomian in a particular cross section and storing it in pd variable....
it gives error as
??? Error using ==> figure
Java exception occurred:
java.lang.NoClassDefFoundError: javax/media/j3d/BoundingBox
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Unknown Source)
at java.lang.Class.privateGetPublicMethods(Unknown Source)
at java.lang.Class.getMethods(Unknown Source)
at com.mathworks.jmi.OpaqueJavaInterface.doesMethodExist(OpaqueJavaInterface.java:407)
Caused by: java.lang.ClassNotFoundException: javax.media.j3d.BoundingBox
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 5 more
Error in ==> gcf at 33
h = figure;
Error in ==> postnewplot>l_newplot at 27
currax = gca;
Error in ==> postnewplot at 15
hAx = l_newplot(vers);
Error in ==> postcrossplot at 368
ax = postnewplot;
I think it is problem with java files and help me regarding this.
thanks for your precious help in advance.
cheers
shanu
6 Replies Last Post 11 giu 2013, 08:10 GMT-4
Posted: 1 decade ago 26 mar 2010, 04:22 GMT-4
hiiiiiiiiiiiiii
I found at last whats the error.............
by starting matlab first..... i have to first run the command "figure" in command line so that matlab reads java jar files in matlab defalut directory after which we can run our command file which can be in some other directory ...................
thanks
cheers
bye
shanu
hiiiiiiiiiiiiii I found at last whats the error............. by starting matlab first..... i have to first run the command "figure" in command line so that matlab reads java jar files in matlab defalut directory after which we can run our command file which can be in some other directory ................... thanks cheers bye shanu
Posted: 1 decade ago 3 gen 2011, 14:22 GMT-5
hey,
i have the same problem right now and dont understand the solution. I will be glad if you share it again...
hey, i have the same problem right now and dont understand the solution. I will be glad if you share it again... Thanks
Posted: 1 decade ago 24 gen 2013, 05:29 GMT-5
I have the same problem too, and don't find the solution. I don't understand how you fix this problem. (My file .m worked correctly since this morning and now I have this error, and I really don't understand why.... I have changed nothing !!)
Thanks to explain more the solution you use...
Cheers,
Laetitia.
Hello, I have the same problem too, and don't find the solution. I don't understand how you fix this problem. (My file .m worked correctly since this morning and now I have this error, and I really don't understand why.... I have changed nothing !!) Thanks to explain more the solution you use... Cheers, Laetitia.
Posted: 1 decade ago 24 gen 2013, 05:54 GMT-5
Realy strange...
I had this error yesterday evening so I turned off my computer. This morning after turning it on, the same error...
I closed Comsol and Matlab, and then opened them again.... And it works... I don't understand what was the problem...
If someone knows a solution, I will be glad to know why this error arrive for the future (in case).
Thanks.
Realy strange... I had this error yesterday evening so I turned off my computer. This morning after turning it on, the same error... I closed Comsol and Matlab, and then opened them again.... And it works... I don't understand what was the problem... If someone knows a solution, I will be glad to know why this error arrive for the future (in case). Thanks.
Posted: 1 decade ago 24 gen 2013, 09:08 GMT-5
This afternoon, same error without reason...
What I did (in fact as Shanu said):
1) Disconnect Comsol to Matlab
2) Open a new Matlab (only Matlab, not Comsol)
3) Run the command "figure" in command line in Matlab
4) Connect Comsol to Matlab (without close the first Matlab)
5) Close the first Matlab
Normally, your code runs and you don't have anymore this error
NB: I did this operation twice before it works, so I'm not sure it's THE solution. Moreover, before this day Matlab/Comsol worked correctly without do this manipulation.
This afternoon, same error without reason... What I did (in fact as Shanu said): 1) Disconnect Comsol to Matlab 2) Open a new Matlab (only Matlab, not Comsol) 3) Run the command "figure" in command line in Matlab 4) Connect Comsol to Matlab (without close the first Matlab) 5) Close the first Matlab Normally, your code runs and you don't have anymore this error NB: I did this operation twice before it works, so I'm not sure it's THE solution. Moreover, before this day Matlab/Comsol worked correctly without do this manipulation.
Posted: 1 decade ago 11 giu 2013, 08:10 GMT-4
after running the Comsol with matlab, add path of the java folder and its subfolder.
