Moving wall boundary condition
Posted 4 mar 2014, 11:23 GMT-5 Computational Fluid Dynamics (CFD) Version 4.3b 10 Replies
in fluid flow simulations with a moving wall boundary condition (a rotation of a circular surface region), I get strong pressure oscillations at the edge of the rotating part of the surface (where the rotating part is in contact with the non-rotating part), that even do not disappear for higher mesh densities. Nevertheless, the velocity distribution seems okay.
Can anyone please comment on that effect?
Thanks, Marcel
If the rotating boundary contacts the non-rotating boundary, you may be specifying both a non-zero value and a zero value for one or more velocity components at the interface of the boundaries. If so, this (non-physical) inconsistency will tend to produce non-physical results near this location.
Luke Gritter
AltaSim Technologies
thanks for your comment. In my case, the non-rotating part is subjected to a symmetry condition (u dot n = 0), so that should be fine. Probably, the high velocity gradients (see attached) cause the fluctuating pressure distribution (also attached). Changing the mesh does not change anything qualitatively, but in pressure quantities.
The question arises if I can trust in the velocities?
Marcel
I can't make out what you're doing in the model from the pictures, but the pressure distribution certainly appears to be erroneous, so I would not trust any of the results. Something in the model setup is generating this non-physical behavior. From the pictures, it appears that you may have fluid on both sides of a moving wall boundary. If so, this may be contributing to the strange pressure results.
Luke Gritter
yes there is fluid also around the rotating part.
I used different meshs and solvers without success. I will try an easier material model to further check that out.
Marcel
Marcel,
Luke Gritter
Hey Luke,
I am confronted with exactly this problem. Do you know how to solve it? I tried to solve it with a function for the moving boundary. At the edge, the velocity of the moving wall is 0 and for the rest of the moving boundary it has a velocity, but the inconsistency still exists. Do you have another idea?
Thank you very much!
Sabine
In most cases, the best approach is to include a small boundary with a Slip BC between the No Slip BC and the Moving Wall BC.
Luke Gritter
I have a slip condition around the moving wall boundary, but the pressure characteristics remains the same. I also tried ramping the velocity at the edge of the moving wall without success.
Any comments would be appreciated!!
Marcel
Thank you very much. I included a slip boundary between the no slip wall and the velocity wall (not an interior wall, but next to the moving wall, on the surface). Is that what you meant? Now I get the right maximum value of the velocity, but the distribution close to the no slip does not seem correct. You can find a screenshot attached.
Do you know why that happens?
Sabine
It is difficult to discern what is going on from the picture. If you can post the model file, I will take a look at it.
Luke Gritter
Thank you very much for your help
Suggested Content
- FORUM Wetting wall boundary condition in LS method together with other boundary condition
- BLOG Tips for Using the Wall Distance Interface
- BLOG Modeling Electroosmotic Flow and the Electrical Double Layer
- BLOG How to Use the Boundary Element Method in Acoustics Modeling
- KNOWLEDGE BASE My Flux Calculation Seems Wrong
