boundary condition
Hi:
I have problem when solved model in plasma flow control, Honestly I search for boundary condition which obtain this condition when dNi,e/dn = 0 , which option in plasma I can get this wall boundary
1 Reply Last Post 30 apr 2014, 10:39 GMT-4
Luke Gritter Certified Consultant
Posted: 1 decade ago 30 apr 2014, 10:39 GMT-4
Zainab,
For electrons, the Insulation boundary condition specifies zero normal electron flux at the boundary. For ions, zero normal flux is specified simply by not applying any surface reaction at a boundary that is external to the plasma. The flux consists of the sum of the migrative and diffusive fluxes, so a zero flux boundary condition does not necessarily specify zero gradient in electron/ion density normal to the boundary.
To specify a zero gradient, the no flux boundary condition needs to be combined with a specification of zero normal electric field (e.g. the Zero Charge boundary condition). The default boundary conditions for external boundaries (Zero Charge, Insulation, no surface reactions) combine to set a zero normal gradient for electron and ion densities.
Luke Gritter
AltaSim Technologies
Zainab, For electrons, the Insulation boundary condition specifies zero normal electron flux at the boundary. For ions, zero normal flux is specified simply by not applying any surface reaction at a boundary that is external to the plasma. The flux consists of the sum of the migrative and diffusive fluxes, so a zero flux boundary condition does not necessarily specify zero gradient in electron/ion density normal to the boundary. To specify a zero gradient, the no flux boundary condition needs to be combined with a specification of zero normal electric field (e.g. the Zero Charge boundary condition). The default boundary conditions for external boundaries (Zero Charge, Insulation, no surface reactions) combine to set a zero normal gradient for electron and ion densities. -- Luke Gritter AltaSim Technologies
