Ivar Kjelberg please help! About the shape of PML in comsol 4.4
Dear Ivar Kjelberg,
I have a question in my simulation. I use the RF module, I was calculating the effective index of the photonic crystal fiber. The shape of the cross section is a hexagonal, the outside is a circle. I want to set the region between the hexagonal and the circle as a PML, and I chose the cylindrical coordinate. But every time comsol said:"Could not find any spherical or cylindrical regions". When I set Cartesian coordinate, the error appear again.
So my question is: does it mean that the pml must be a standard rectangle, circle or concentric? (But in comsol v4.2. the pml region can be arbitrary, it don't have this problem.)
I will appreciate it very much for your helps!
6 Replies Last Post 19 dic 2014, 21:24 GMT-5
Hello Meng
Posted: 10 years ago 8 ott 2014, 05:03 GMT-4
I have the same problem. Does anybody know how to solve it?
Posted: 10 years ago 13 ott 2014, 05:48 GMT-4
I solved it myself, do not set an arbitrary shape of PML, just use circular or rectangular. By careful mesh, the results will be good!
Posted: 10 years ago 14 ott 2014, 11:48 GMT-4
Have you solved for 3D spherical or rectangular PML? when i tried i get some other kind of error.
[QUOTE] I solved it myself, do not set an arbitrary shape of PML, just use circular or rectangular. By careful mesh, the results will be good! [/QUOTE] Have you solved for 3D spherical or rectangular PML? when i tried i get some other kind of error.
Posted: 10 years ago 21 ott 2014, 02:27 GMT-4
3D spherical maybe easier, you can refer to the example model of comsol(for example, dipole antenna ), do not forget to use swept mesh!
I hope this help.
3D spherical maybe easier, you can refer to the example model of comsol(for example, dipole antenna ), do not forget to use swept mesh! I hope this help.
Posted: 10 years ago 19 dic 2014, 16:50 GMT-5
I am new to Comsol. I tried to make a simple 2D axisymmetric model with a core circular region 5um in radius of refractive index 1.7 and 0.5 um thick outer circular region of refractive index 1.6. Then added PML at radius 20um and meshed. I selected geometry cylindrical. When I compute, the error is "could not fund any cartesian regions - Feature : perfectly matched layer"
What should I do? Thanks
Hello, I am new to Comsol. I tried to make a simple 2D axisymmetric model with a core circular region 5um in radius of refractive index 1.7 and 0.5 um thick outer circular region of refractive index 1.6. Then added PML at radius 20um and meshed. I selected geometry cylindrical. When I compute, the error is "could not fund any cartesian regions - Feature : perfectly matched layer" What should I do? Thanks
Posted: 10 years ago 19 dic 2014, 21:24 GMT-5
When the geometry is set to be cylindrical, the problem should have been solved. Moreover, your PML is too thick, one or two lmd is ok!
