MATLAB Parallel Toolbox parfor: using mphstart() more than once
my problem is that a MATLAB instance refuses to use mphstart() more than once in its lifetime.
I need to reconnect because I want to use the MATLAB Parallel Computing Toolbox with parfor to run lots of Comsol models in parallel. Unfortunately if a MATLAB worker is re-assigned with a new Comsol task, it cannot connect to a Comsol server although its workspace is cleared completely.
Has anyone an explaination for this or knows how to fix this?
Chris
1 Reply Last Post 1 ago 2017, 04:50 GMT-4
Hello Chris Shor
Posted: 7 years ago 1 ago 2017, 04:50 GMT-4
connect each worker only once in the first function call.
this can be done for example with isempty(variable)
connect each worker only once in the first function call. this can be done for example with isempty(variable)
