In transient time domain analysis, is there any way to visualize 2D E-field of a selected frequency?
Dear Friends,
Your comments regarding my concern is highly appreciated. Please take a look.
My concern is: In transient time domain analysis, is there any way to visualize 2D E-field of a selected frequency? And for that what modification is necessary in my simulation (Please find the attached file )?
I saw that we can observe 2D E-field in the whole ring resonator at different time steps (like in Figure 1). But I am interested to observe the 2D-E-field in the ring resonator at only one selected single frequency like 5 THz. If you could please help me out, I would be really grateful.
With best regards,
Raju
3 Replies Last Post 27 ago 2014, 22:02 GMT-4
Posted: 1 decade ago 13 ago 2014, 21:46 GMT-4
I recommend using the frequency-domain formulation when investigating behavior at fixed frequencies.
Posted: 1 decade ago 25 ago 2014, 09:26 GMT-4
Thanks a lot for your reply (@ Robert Koslover).
Actually, I used time domain solver because I had to use optical nonlinearity d33 property in order to observe difference frequency generation in THz region for two chosen appropriate input optical waves. In time domain it is really easy to define d33. There, at the wave equation section, I chose Remnant electric displacement and defined Dr=d33*temw.Ez^2.
But in frequency domain, I could not find any way so far to define d33 property in the nonlinear ring. Actually, if you could tell me if there is a way to define nonlinearity in frequency domain, I could try the simulation in frequency domain and it would be a great help for me. Again, thanks a lot for helping me out.
Thanks a lot for your reply (@ Robert Koslover). Actually, I used time domain solver because I had to use optical nonlinearity d33 property in order to observe difference frequency generation in THz region for two chosen appropriate input optical waves. In time domain it is really easy to define d33. There, at the wave equation section, I chose Remnant electric displacement and defined Dr=d33*temw.Ez^2. But in frequency domain, I could not find any way so far to define d33 property in the nonlinear ring. Actually, if you could tell me if there is a way to define nonlinearity in frequency domain, I could try the simulation in frequency domain and it would be a great help for me. Again, thanks a lot for helping me out.
Posted: 1 decade ago 27 ago 2014, 22:02 GMT-4
Oh. It makes sense that your problem has to be solved in time-domain, if there are non-linearities involved. I suspect the most straightforward way to study the frequency content in post-processing is to export the data and work with it in MatLab (or similar), employing Fourier transforms.
