domain index
I'm trying to write a code where i need to determine the index of different domains so i can attribute different charges and dielectric constants. this procedure is in a loop where in every step these constants change so i need to know the index of each domain. is there any way ?
2 Replies Last Post 10 lug 2017, 05:48 GMT-4
Hello Micheal Anderson
Posted: 8 years ago 9 lug 2017, 19:13 GMT-4
Hi Micheal,
Did you succeed to solve your problem ?
Because I want to do the same thing...
Hi Micheal, Did you succeed to solve your problem ? Because I want to do the same thing...
Lorant Olasz COMSOL Employee
Posted: 8 years ago 10 lug 2017, 05:48 GMT-4
Hi Loic,
Instead of domain numbers I would like to direct your attention to selections. Selections will enable you to do the type of model set-up that I understand you would like to do.
The following video series is a good introduction to selections:
www.comsol.com/video/selections-streamline-comsol-multiphysics-modeling-workflow
The apps linked to from the blogs below are just a couple of examples you will find on our website (if you search for "selections") of how powerful selections are in helping with assigning physics to geometry:
www.comsol.com/blogs/intro-to-optimizing-mixer-design-by-creating-an-app/
www.comsol.com/blogs/how-to-dynamically-modify-geometries-in-simulation-apps/
There is also a blog series discussing selections in the context of LiveLink for MATLAB, which you will find here:
www.comsol.com/blogs/tag/working-with-m-files/
Lorant
Hi Loic, Instead of domain numbers I would like to direct your attention to selections. Selections will enable you to do the type of model set-up that I understand you would like to do. The following video series is a good introduction to selections: https://www.comsol.com/video/selections-streamline-comsol-multiphysics-modeling-workflow The apps linked to from the blogs below are just a couple of examples you will find on our website (if you search for "selections") of how powerful selections are in helping with assigning physics to geometry: https://www.comsol.com/blogs/intro-to-optimizing-mixer-design-by-creating-an-app/ https://www.comsol.com/blogs/how-to-dynamically-modify-geometries-in-simulation-apps/ There is also a blog series discussing selections in the context of LiveLink for MATLAB, which you will find here: https://www.comsol.com/blogs/tag/working-with-m-files/ Best regards, Lorant
