Adding a momentum source in a beaker without stirrer
Hi, I am trying to model a set of chemical reactions using a very simple set up. The reactions occur in a beaker with water as solvent. The solution in the beaker needs to be stirred continuously. While modelling this set up using COMSOL I do not wish to use the Mixer Module (Rotating machinery), instead I wish to add a momentum source term which will act similar as if there is a physical stirrer present in the beaker. The mixing will occur as a result of the momentum source term. Is it possible to do this using COMSOL? If yes, then please explain how.
Thanks.
0 Replies Last Post 25 set 2014, 02:08 GMT-4
Hello Pradeep Maheshwari
