Coil with user-defined voltage
I need to find magnetic field, as a function of time, in the system of coils where voltage is a user-defined function of time. Can I use CA/DC, and where I set the dependence V(t).
Thank you
1 Reply Last Post 30 set 2014, 09:04 GMT-4
Nirmal Paudel COMSOL Employee
Posted: 10 years ago 30 set 2014, 09:04 GMT-4
Hi Larisa,
The coil can be excited with voltage input as a function of time as shown in the attached model.
Within Multi-Turn Coil 1 -> Multi-Turn Coil -> Coil excitation (Voltage) -> Voltage = 1[V]*sin(2*pi*50[Hz]*t).
The same excitation can also be used for Single Turn Coil as well.
Best Regards,
Nirmal Paudel,
COMSOL Employee
USA
Hi Larisa, The coil can be excited with voltage input as a function of time as shown in the attached model. Within Multi-Turn Coil 1 -> Multi-Turn Coil -> Coil excitation (Voltage) -> Voltage = 1[V]*sin(2*pi*50[Hz]*t). The same excitation can also be used for Single Turn Coil as well. Best Regards, Nirmal Paudel, --------------------------- COMSOL Employee USA
