Transient electric field under impulse voltage with nonlinear materials
Hi all,
I am trying to model a nonlinear permittivity material in a cable termination under impulse voltage using Version 5. I used AC/DC module electric currents (ec) and electrical circuit (cir) to produce impulse voltage, and used an analytic function to define the relative permittivity as a function of electric stress (ec.normE). When I run it, I got the following error message.
Attempt to evaluate negative power of zero.
- Function: ^
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.ec.normE@VDN$t@VDN${conj@8}
- Defined as: ((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt)))))
- Variable: comp1.ec.epsilonrrr@VDN$t@VDN${conj@8}
- Defined as: (dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt)))))))))
- Variable: comp1.ec.chirr@VDN$t@VDN${conj@8}
- Defined as: ((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt))))))))))
- Variable: comp1.ec.Pr@VDN$t@VDN${conj@8}
- Defined as: (comp1.ec.Er*(epsilon0_const*(((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt)))))))))))))
- Variable: comp1.ec.Dr@VDN$t@VDN${conj@8}
- Defined as: ((comp1.ec.Er*(epsilon0_const*(((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt))))))))))))))
- Variable: comp1.ec.Jdr@VDN${conj@8}
- Defined as: (((comp1.ec.Er*(epsilon0_const*(((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt)))))))))))))))
- Variable: comp1.ec.Jr@VDN${conj@8}
- Defined as: ((((comp1.ec.Er*(epsilon0_const*(((dcomp1.mat5.def.Dk1_dDk1__x__internalArgument(((comp1.ec.normE*unit_m_cf)/unit_V_cf))*((1/unit_V_cf)*(unit_m_cf*(((((realdot(comp1.ec.Er,comp1.ec.Er)+realdot(comp1.ec.Ez,comp1.ec.Ez))^(-0.5))*0.5)*(((-(comp1.Vrt)))+((-(comp1.Vrt))))))))))))))))
- Expression: d(d((2*(comp1.ec.Jr*test(comp1.Vr)+comp1.ec.Jz*test(comp1.Vz))*comp1.ec.d*pi*r)*(dvol),{test@4}),{conj@8})
- Feature: Time-Dependent Solver 1 (sol1/t1)
Can anybody help me on the reason and solution? Thanks a lot.
PS: I run the same model with Electrostatics (es), that is DC, without any problem.
3 Replies Last Post 17 feb 2015, 11:53 GMT-5
Posted: 10 years ago 14 nov 2014, 10:57 GMT-5
I forgot to attach my file.
Can anybody help me please?
I forgot to attach my file. Can anybody help me please?
Posted: 9 years ago 22 gen 2015, 08:31 GMT-5
You have expressions in Probes (temw.Er, and temw.Ez) which seem undefined. I suggest to change or disable them.
Apart from that, there's a problem with derivatives of certain expressions (at Material 5). You can avoid them with nojac() operator, in order to take them out of Jacobian. Particularly, you can replace Dk1(ec.normE) with nojac(Dk1(ec.normE)) for the relative permittivity of Material 5.
Also, there are two domains (1 and 4) which you don't solve. Is that your intention?
Jesus.
Hi, You have expressions in Probes (temw.Er, and temw.Ez) which seem undefined. I suggest to change or disable them. Apart from that, there's a problem with derivatives of certain expressions (at Material 5). You can avoid them with nojac() operator, in order to take them out of Jacobian. Particularly, you can replace Dk1(ec.normE) with nojac(Dk1(ec.normE)) for the relative permittivity of Material 5. Also, there are two domains (1 and 4) which you don't solve. Is that your intention? Jesus.
Posted: 9 years ago 17 feb 2015, 11:53 GMT-5
Hi Jesus,
It works. Thank you very much.
Hi Jesus, It works. Thank you very much.
