Comsol 4.0 Level Set Method
I have just started to play around with COMSOL version 4.0. It seems that the level set method has not been implemented. Am I correct or have I just failed to find it? The level set method or an alternative is an essential need for me.
3 Replies Last Post 23 mar 2015, 07:52 GMT-4
Posted: 1 decade ago 10 mag 2010, 05:30 GMT-4
Look in Fluid Flow->Multiphase Flow->Two-Phase Flow, Level Set.
There you will find the precoupled multiphysics interface with Navier-Stokes and Level Sets, which I assume is the most common modeling scenario.
I you want to experiment with Level Set only you can find the interface here:
Mathematics>Moving Interface>Level Set
Niklas Rom, COMSOL
Look in Fluid Flow->Multiphase Flow->Two-Phase Flow, Level Set. There you will find the precoupled multiphysics interface with Navier-Stokes and Level Sets, which I assume is the most common modeling scenario. I you want to experiment with Level Set only you can find the interface here: Mathematics>Moving Interface>Level Set Niklas Rom, COMSOL
Posted: 1 decade ago 10 mag 2010, 13:27 GMT-4
Thanks very much - it's taking a while for me to get used to the new interface.
Posted: 1 decade ago 23 mar 2015, 07:52 GMT-4
how to track a particular point of the interface in level set method
