Importing Mesh from Mimics into Comsol 4
I have mphtext file generated from Mimics. I have imported them into Comsol but I do not know where to go from here. I would be grateful if someone could help please?
7 Replies Last Post 5 nov 2010, 16:05 GMT-4
Posted: 1 decade ago 28 mag 2010, 07:58 GMT-4
I would say create geometry from mesh: Menu-> Mesh -> generate geometry from mesh to al
Posted: 1 decade ago 28 mag 2010, 08:02 GMT-4
Thanks for your reply. Do you how to do this in version 4 please...it's completely different from 3.5?
Hi, Thanks for your reply. Do you how to do this in version 4 please...it's completely different from 3.5?
Posted: 1 decade ago 30 mag 2010, 16:56 GMT-4
These are the steps we have been doing:
1. Create the volume mesh files in mimics.
2. In Comsol version 4 we choose 3D>structural module> solid mechanics. We selected stationary analysis.
3. We imported 5 mesh files (which is in fact 5 parts) under the mesh interface in the model builder.
4. Then we assigned material properties to each parts.
5. We created contact pairs and identity pairs.
6. Under the solid mechanics interface in the model builder we set a face load and a fixed constraint (contact pairs and continuity pairs were also inserted as a follow up to step 5).
7. We generated a sequence from the study and compute.
(Also the finalize feature node was set as form an assembly)
And there is no stress distribution at all in our model. All we get is a green model starring blankly at us.
Is there anything wrong in the steps above or maybe it might be with our imported mess?
Thanks for answering
Cheers
Dilen
These are the steps we have been doing: 1. Create the volume mesh files in mimics. 2. In Comsol version 4 we choose 3D>structural module> solid mechanics. We selected stationary analysis. 3. We imported 5 mesh files (which is in fact 5 parts) under the mesh interface in the model builder. 4. Then we assigned material properties to each parts. 5. We created contact pairs and identity pairs. 6. Under the solid mechanics interface in the model builder we set a face load and a fixed constraint (contact pairs and continuity pairs were also inserted as a follow up to step 5). 7. We generated a sequence from the study and compute. (Also the finalize feature node was set as form an assembly) And there is no stress distribution at all in our model. All we get is a green model starring blankly at us. Is there anything wrong in the steps above or maybe it might be with our imported mess? Thanks for answering Cheers Dilen
Posted: 1 decade ago 2 nov 2010, 01:31 GMT-4
I also have a mimics mesh, and i can import it in comsol 3.5 but cannot create a geometry from the mesh
any ideas on why i can't ? i get the error 2211
thanks,
T
I also have a mimics mesh, and i can import it in comsol 3.5 but cannot create a geometry from the mesh any ideas on why i can't ? i get the error 2211 thanks, T
Posted: 1 decade ago 5 nov 2010, 00:58 GMT-4
Hi.
Have you figured out how to import and use the mesh file from mimics? I am stuck here now. Thanks.
Hi. Have you figured out how to import and use the mesh file from mimics? I am stuck here now. Thanks.
Posted: 1 decade ago 5 nov 2010, 04:35 GMT-4
No I'm using version 4 of comsol and we can't create a geometry out of a mesh in comsol.
Hi, No I'm using version 4 of comsol and we can't create a geometry out of a mesh in comsol.
Posted: 1 decade ago 5 nov 2010, 16:05 GMT-4
So, Are there any other methods to do simulation with a mesh file from Mimics? I have already had the 3D model in Mimics.
So, Are there any other methods to do simulation with a mesh file from Mimics? I have already had the 3D model in Mimics. Thanks
