9 years ago
14 mar 2015, 09:00 GMT-4
Add a reaction term to the diffusion equation:
dcA/dt = DA*nabla^2 cA + R
R = -k*cA
or whatever reaction term that is pertinent to your reaction.
br
Lasse
R = -k*cA
br
Lasse
9 years ago
14 mar 2015, 09:42 GMT-4
Hi Lasse,
thank you for your fast reply.
But I still have an understanding problem. i know that I can add a reaction term for my diffusion but how does COMSOL know that the consumption only takes place at a certain domain? Can I implement this in any way?
Thanks for your help
Hi Lasse,
9 years ago
15 mar 2015, 04:10 GMT-4
When you define the reaction term, you must click the domain where you want it to take place. Otherwise it won't have any effect on the calculation.
Lasse
Lasse
9 years ago
15 mar 2015, 04:38 GMT-4
Hi Lasse,
I did a mistake in my last answer, I wanted to say boundary instead of domain, sorry.
I know that I have to select the domain and that's where I have trouble because my reactor is a square. Is there a possibility to select a boundary where the reaction takes place? Or do I have to create a square reactor with four seperate lines which form a square and then select one domain?
Thanks for your help.
Hi Lasse,
9 years ago
15 mar 2015, 04:44 GMT-4
OK, now I see.
If a reaction takes place on the boundary, then it is not written as a reaction term in the diffusion equation, but as a flux boundary condition.
Inward flux: -k*cA
but now notice that the units of k, the reaction rate constant, is m/s in order to have flux in mol/(m^2*s).
BR
Lasse
OK, now I see.
Inward flux: -k*cA
BR
Lasse
9 years ago
15 mar 2015, 06:26 GMT-4
Thank you Lasse, really appreciate your help.
So if I understood it correctly. For the species B which gets created at the boundary I can just do the same with an inward flux, right?
9 years ago
15 mar 2015, 09:30 GMT-4
Yes, +k*cA.
Yes, +k*cA.
8 years ago
12 mag 2016, 23:36 GMT-4
Hi, I am solving the coupling of poisson equation and current continuity equations in the Transport of Diluted Species, However, what I am confused is that whether the right source term of the continuity equation can be represented by the reaction rate term in the module .
the equations are in the attached file.
Thanks!
Thanks!
