9 lug 2010, 08:27 GMT-4
I've found the problem.
When v3.5a frequency dependent models are brought across into v4 the freqency domain needs to be re-activated in advanced settings. Once this is done the admittance becomes available as a variable.
3 lug 2011, 16:07 GMT-4
Dear David,
I am also trying to simulate impedance for a parallel plate capacitor with water as a dielectric. I do not see a change in the value of impedance/admittance with frequency. Can you shed some light on this. Do we need to define permittivity and conductivity of the solution as a function of frequency. If you can share your model which can give a fair idea about the variables defined and the boundary conditions, it will be of great help. I have tried simulating in both version 4.0 and 3.5, so model in any of the versions would be of help.
Thanks in anticipation
Nidhi
Dear David,
Nidhi
6 lug 2011, 08:17 GMT-4
Dear Nidhi,
Thanks for your interest in this work.
You should see a change in admittance (capacitive component) with changes in frequency without specifying frequency dependent material properties as Xc=1/(2*pi*f*C), where C=ep*A/d.
The model should be set-up as follows:
- Electric currents application mode
- Frequency domain study
- The energised boundary should be a 'terminal'
- The grounded boundary is of course 'ground'
- The open boundaries are 'electric insulation'
I have attached a basic model for reference.
Meshing is critical and you may need to use the 'adaptive mesh refinement' tools for an accurate solution.
I hope this had been of assistance.
David.
Dear Nidhi,
David.
7 lug 2011, 05:02 GMT-4
Thanks David for sending the information across. Can you please let me know which version of comsol you have used for the model. I have not been able to open the file in Comsol 4.0, it says that an advanced version has been used to make the model. If possible can you send a 4.0 compatible version of the model?
Nidhi
Nidhi
12 lug 2011, 07:14 GMT-4
Hi Nidhi,
I am using COMSOL 4.1 and do not have any older versions installed on my computer.
Have a read of the example (tunable capacitor) in the COMSOL model library as it will help when setting up your model.
David.
Hi Nidhi,
David.
