Merge two mesh
I want to merge 2 mesh. A cylinder with a slab. How can I do that?
2 Replies Last Post 27 apr 2013, 11:18 GMT-4
Hello Mashallah Rezakazemi
Posted: 1 decade ago 27 mag 2011, 04:42 GMT-4
I've got a similar problem. I would like to merge two meshes imported from Matlab in Comsol 3.5a.
At p. 132 of Matlab Interface Guide, it is explicitly written "Importing a mesh from a file removes all geometry objects from the current geometry".
Therefore, I saved each imported mesh into a separate .mph file (I payed attention to create geometry from mesh before saving each file). Then, I used File -> Merge Component, but it doesn't work.
Any tip or suggestion to overcome this difficulty?
Many thanks in advance!
Best Regards,
PM
Hi, I've got a similar problem. I would like to merge two meshes imported from Matlab in Comsol 3.5a. At p. 132 of Matlab Interface Guide, it is explicitly written "Importing a mesh from a file removes all geometry objects from the current geometry". Therefore, I saved each imported mesh into a separate .mph file (I payed attention to create geometry from mesh before saving each file). Then, I used File -> Merge Component, but it doesn't work. Any tip or suggestion to overcome this difficulty? Many thanks in advance! Best Regards, PM
Posted: 1 decade ago 27 apr 2013, 11:18 GMT-4
Hi, I have meet the same problem, did anyone solve this problem?
