Comsol reference manual
I can't find any current reference manuals on comsol v5.0 and above. Where can I get the Structural mechanics users guide and Comsol reference manual for version 5.0 or 5.1
4 Replies Last Post 21 set 2015, 09:01 GMT-4
Posted: 9 years ago 7 lug 2015, 20:08 GMT-4
if you are using a windows machine, the manuals are in the installation directory. The short cut is:
start/comsol directory/documentation
the full path is something along this:
Program Files\COMSOL\COMSOL4.3\Multiphysics\doc\pdf
if you are using a windows machine, the manuals are in the installation directory. The short cut is: start/comsol directory/documentation the full path is something along this: Program Files\COMSOL\COMSOL4.3\Multiphysics\doc\pdf
Posted: 9 years ago 8 lug 2015, 01:04 GMT-4
Thanks. I have found it now
Posted: 9 years ago 21 set 2015, 06:41 GMT-4
please i need reference manual
Posted: 9 years ago 21 set 2015, 09:01 GMT-4
If you are looking for documentation for a product you are licensed for:
You can reach the documentation through the File>Help>Documentation menu.
Alternatively, as AC pointed out above, you can make your way to the COMSOL installation folder (By default, on Windows, on the current version, it's C:/Program Files/COMSOL/COMSOL51/Multiphysics/ ) , and then look for the doc folder and then pick between html or pdf (I prefer pdf). In there, select the product whose documentation you are looking for.
If you are looking for documentation for a product you are not licensed for:
Contact your COMSOL representative: www.comsol.com/contact
If you are looking for documentation for a product you are licensed for: ====================================================== You can reach the documentation through the File>Help>Documentation menu. Alternatively, as AC pointed out above, you can make your way to the COMSOL installation folder (By default, on Windows, on the current version, it's C:/Program Files/COMSOL/COMSOL51/Multiphysics/ ) , and then look for the doc folder and then pick between html or pdf (I prefer pdf). In there, select the product whose documentation you are looking for. If you are looking for documentation for a product you are not licensed for: ========================================================= Contact your COMSOL representative: http://www.comsol.com/contact Jeff
