Segregated solver for one way coupling
Hey All,
Let's say I have a field A and B. Field B depends on A, but A does not depend on B (one way coupling).
I can imagine that this should be solved in a segregated solver. How can I define this in a segregated solver, as there are two options there: tolerance termination and iteration number?
Many thanks
Danial
2 Replies Last Post 17 ago 2010, 15:27 GMT-4
Posted: 1 decade ago 17 ago 2010, 13:21 GMT-4
anyone?
anyone?
Andrew Prudil Nuclear Materials
Posted: 1 decade ago 17 ago 2010, 15:27 GMT-4
In that case I would create two segregated groups. First solving for A (independent) which would be set to terminate by tolerance. The second group I would put B, and have it terminate after 1 iteration.
I'm not sure that this is the most efficient way (it might iterate once more to see that A has not changed because of B and that B has not changed because of the change in B), but it should work.
In that case I would create two segregated groups. First solving for A (independent) which would be set to terminate by tolerance. The second group I would put B, and have it terminate after 1 iteration. I'm not sure that this is the most efficient way (it might iterate once more to see that A has not changed because of B and that B has not changed because of the change in B), but it should work.
