Problem with electromagnetics
I am trying to simulate electromagnetic suspension for automobiles using COMSOL 4.3b. I am experimenting everything in the software specifically in AC/DC physics using video tutorials since I am totally new to this software. I am not able to come to point of selecting the exact physics for my concept. I am giving electric current 'A' as input to the windings surrounding the core and expecting output in terms of Lorentz force or magneto motive force created at the top end faces of the electromagnet due to current. Please suggest me some papers relating to the topic if possible.
I am hoping for someone to please help me out with this problem that would be really grateful to me.
Thanks.
2 Replies Last Post 8 set 2015, 14:50 GMT-4
Nirmal Paudel COMSOL Employee
Posted: 10 years ago 4 set 2015, 16:03 GMT-4
The following example model demonstrate the calculation of Lorentz force on the conductive plate where the eddy currents is induced by the current carrying conductor located above it. The core is not included in this model.
www.comsol.com/model/induction-currents-from-circular-coils-124
If you wish to model the coil and a core, please refer to this example:
www.comsol.com/model/eddy-currents-in-a-cylinder-128
Note that the core material is a conductive and non-magnetic material, but you could simply change the material to something like Soft Iron (magnetic material).
Hope this will be useful.
Best Regards,
Nirmal Paudel
Hi, The following example model demonstrate the calculation of Lorentz force on the conductive plate where the eddy currents is induced by the current carrying conductor located above it. The core is not included in this model. http://www.comsol.com/model/induction-currents-from-circular-coils-124 If you wish to model the coil and a core, please refer to this example: http://www.comsol.com/model/eddy-currents-in-a-cylinder-128 Note that the core material is a conductive and non-magnetic material, but you could simply change the material to something like Soft Iron (magnetic material). Hope this will be useful. Best Regards, Nirmal Paudel
Posted: 10 years ago 8 set 2015, 14:50 GMT-4
Thank you so much for your reply Sir. But one question Sir, how can I change the direction of current in the coils. My study is little complicated. It consists of the electromagnets placed one above the other separated by small air gap. The current direction (DC) in one coil of one electromagnet is opposite to the coil of another electromagnet above it such that both electromagnets create repulsive forces between them.
I hope if it can be solved.
Thank you so much for your reply Sir. But one question Sir, how can I change the direction of current in the coils. My study is little complicated. It consists of the electromagnets placed one above the other separated by small air gap. The current direction (DC) in one coil of one electromagnet is opposite to the coil of another electromagnet above it such that both electromagnets create repulsive forces between them. I hope if it can be solved.
