Force calculation between a multi-turn coil and a permanent magnet
Posted 18 set 2015, 02:34 GMT-4 Low-Frequency Electromagnetics Version 5.1 3 Replies
I'm trying to simulate the force between a multi-turn coil and a permanent magnet.
The magnet is inside of the coil. It has to move against a flexure to reach its resting position.
Therefore i want to know the force with which the coil is able to move the magnet.
I thought i can get the force in dependence of the distance to between the coil and magnet.
But i only get the force of the coil and it is not changing with the increasing distance (implemented by a moving mesh) of the magnet.
Can someone give me a hint? Is it a practical way to simulate the increasing distance between the coil and the magnet with a moving mesh?
Thank you!
Jan
Thank you!
Jan
3 Replies Last Post 24 set 2015, 03:51 GMT-4
