general pde mode, spherical coordinates
Hi, everybody
I want to solve a differential equation in spherical coordinates (just “R” component dependent)
By “General PDE mode” (comsol3.4).
But there is no default spherical coordinates in the comsol .
Now how can I resolve this problem?
The simulation geometry is as following:
A----------------------------------------B
Regards
parviz
6 Replies Last Post 20 feb 2013, 13:13 GMT-5
Posted: 1 decade ago 11 mar 2011, 01:24 GMT-5
define the coordinate yourself, see the KB (and other treads on the FORUM)
Hi define the coordinate yourself, see the KB (and other treads on the FORUM) -- Good luck Ivar
Posted: 1 decade ago 11 mar 2011, 13:33 GMT-5
thanks ivar
but i can not find the KB.
can i pre-arrenge the my equation and so, use the cartesian coordinates?
regards
parviz
thanks ivar but i can not find the KB. can i pre-arrenge the my equation and so, use the cartesian coordinates? regards parviz
Posted: 1 decade ago 11 mar 2011, 15:34 GMT-5
sorry, KB is the sort for the official Knowledge Base of COMSOL
www.comsol.eu/support/knowledgebase/browse/900/
Hi sorry, KB is the sort for the official Knowledge Base of COMSOL http://www.comsol.eu/support/knowledgebase/browse/900/ -- Good luck Ivar
Posted: 1 decade ago 12 mar 2011, 15:20 GMT-5
thanks ivar
regards
parviz
thanks ivar regards parviz
Posted: 1 decade ago 20 feb 2013, 08:26 GMT-5
I am facing the same problem you had few years ago. Could you please tell me how you solved this issue?
I have to model mass transport in spherical coordinates.
I cannot access to KB that's why I am asking.
Thanks in advance
Hi I am facing the same problem you had few years ago. Could you please tell me how you solved this issue? I have to model mass transport in spherical coordinates. I cannot access to KB that's why I am asking. Thanks in advance
Posted: 1 decade ago 20 feb 2013, 13:13 GMT-5
you can define the spherical coordinate system, andthen use the references of the "user coordinate" system "sys2..." to define or transform your variable (oth ways actually)
But COMSOL by default work in cartesian coordiantes so you need to map ack and perhaps, for the results forward ;)
Hi you can define the spherical coordinate system, andthen use the references of the "user coordinate" system "sys2..." to define or transform your variable (oth ways actually) But COMSOL by default work in cartesian coordiantes so you need to map ack and perhaps, for the results forward ;) -- Good luck Ivar
