Java Runtime Environment error
Posted 28 lug 2011, 07:37 GMT-4 Results & Visualization, Studies & Solvers 15 Replies
A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x0000003da3efbc6c, pid=6909, tid=46912497239488
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) 64-Bit Server VM (16.3-b01 mixed mode linux-amd64 )
# Problematic frame:
# C [libgtk-x11-2.0.so.0+0xfbc6c] gtk_icon_set_render_icon+0x58c
Does anyone know how to resolve it...
Regards
Hello Narendra Patil
I get the same kind of error. I am working under Ubuntu 11.04.
Any clue for solution?
Massimo
[thread 53107568 also had an error]# A fatal error has been detected
by
# SIGSEGV (0xb) at pc=0x00e503e1, pid=27669, tid=3077753040
# Java VM: Java HotSpot(TM) Client VM (16.3-b01 mixed mode linux-x86 )
# C [libc.so.6+0x703e1] cfree+0x31
# An error report file with more information is saved as:
# /home/ablanchard/hs_err_pid27669.log
This is the reply from COMSOL Support:
I found this bug report which looks similar to yours:
bugs.launchpad.net/ubuntu/+source/overlay-scrollbar/+bug/789123
You may want to try the suggestion in comment 18 and 23. Try to disable the
overlay scrollbars to see if that helps.
I disabled the overlay scrollbars and haven't had that problem again. Just follow the link above for instructions.
Cheers
Software rendering is activated by the starting Comsol Multiphysics with the following flag:
comsol -3Drend sw
After the first time this setting will be saved and used as default when starting Comsol Multiphysics.
The setting can be changed from within the program "Option -> Preferences -> Graphics - 3D rendering -> OpenGL
Jonas
Did anybody find a solution.
I find this error when I try to run a eclipse Java ,COMSOL API
thank you in advance
I seem to have the same problem on Windows 64bit, version 4.3b, it happens in the BeamModelDemo example at these lines:
SwingGraphicsPanel graphicsPanel = new SwingGraphicsPanel("window1", "Window1");
mainPanel.add(graphicsPanel, BorderLayout.CENTER);
[code]
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000007fee9baba56, pid=1060, tid=3788
# JRE version: Java(TM) SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.45-b08 mixed mode windows-amd64 compressed oops)
# C [cs3d_ogl.dll+0xba56]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
[/code]
Ubuntu 14.04 x64
Comsol was succesfully installed and started. Getting following error while clicking "help" or "about" menu:
"A fatal error has been detected by the Java Runtime Environment"
I tried to run the program on Mint 17 with Cinnamon or Mate after. Same error.
Since ubuntu 12.04 is officially supported, I installed latest available ubuntu 12.04.4. And got same error with java.
Running Ubuntu 14.04, x64.
COMSOL crashes with JAVA runtime error while changing parameters. It *always* crashes when trying to access Help menu or Documentation.
This problem did not occur in Ubuntu 12.04 (checked and verified with same version of COMSOL).
Tried removing 'overlay-scrollbar' in Ubuntu 14.04. The problem still persists.
Here is the error message:
java version "1.7.0_65"
OpenJDK Runtime Environment (IcedTea 2.5.1) (7u65-2.5.1-4ubuntu1~0.14.04.1)
OpenJDK 64-Bit Server VM (build 24.65-b04, mixed mode)
# SIGSEGV (0xb) at pc=0x00007ff9d32ed2a1, pid=2791, tid=140714205308736
# C [libsoup-2.4.so.1+0x6c2a1] soup_session_feature_detach+0x11
# /home/----/hs_err_pid2791.log
# java.sun.com/webapps/bugreport/crash.jsp
Aborted (core dumped)
"COMSOL crashes when trying to access the documentation"
www.comsol.com/support/knowledgebase/1178/
But let me share some top secret info FOR LINUX COMSOL USERS only.
The ONLY linux distro that runs Comsol 4.4 error-free is a Mint Linux 13 Maya.
I had not any errors on Mint Linux Maya 13 64bit. (based on 12.04 ubuntu)
But (!) I did have those above mentioned java-errors with newer distros such as the ones based on 14.04 ubuntu or 14.10.
And (!) I did have same errors on 12.04 ubuntu so far. (wtf)
So, keep that in mind. Thus hopefully I saved some of your time.
PS: same java errors are on comsol 5.0. So don'taskdon'tell )))
Interestingly, this same error only occured on the "about COMSOL multiphysics" option. I had no issues accessing help, documentation etc.
Make sure to close and re-open COMSOL.
I resolved a similar issue with COMSOL 5.1 by selecting: Option/preference/help/Web browser
Hi, what is your system? Mine is windows 7. I have the similar problem, even though I have changed the openGL to software, it still keeps crashing. I will crash if it continues.
[code]
[/code]
Dear Dmitry,
I faced the same error. It will be great if you can share any solution you got for this problem.
thanks
Ashish Mishra
[code]
[/code]
Dear Daniel,
I am facing the same error on windows 7. Can you share any solution of the problem you got?
thanks
Ashish
Suggested Content
- FORUM Java Unsuccessful link Error
- BLOG Building COMSOL Multiphysics Models with Excel® and Visual Basic®
- BLOG Efficiently Distribute Lightweight Compiled Applications
- BLOG Fine-Tuning an HVAC System Design with Simulation
- KNOWLEDGE BASE LDAP configuration for a Model Manager server using Apache Directory Studio
