Export parametric 2D surface plot to multiple images
I did a parametric sweep simulation with a combined material sweep. Now I defined a surface isoplot which I want to export to an image file. And I want to do that for each combination of parameter and material, which results to a number of images. To do this manually needs quite some time, so I wondered if there is a way to automatically export each combination to a separate image file based on the defined export node?
I'd like to define a description with the parameter value and this value should be part of the file name.
Any help is appreciated.
Andre
4 Replies Last Post 4 feb 2016, 03:57 GMT-5
Posted: 9 years ago 13 gen 2016, 08:38 GMT-5
Hi Andre,
Repetitive post-processing tasks like that can be automated in an app, by making use of a "for" loop in a method.
Hi Andre, Repetitive post-processing tasks like that can be automated in an app, by making use of a "for" loop in a method. Best, Jeff
Posted: 9 years ago 3 feb 2016, 02:43 GMT-5
Hi Jeff,
thanks for your reply. In the last weeks I was not able to work on this problem.
Because I'm on a linux system, I can't use the application builder. Is it possible to automate post processing tasks inside "core" COMSOL?
Or do you mean a different kind of app?
Andre
Hi Jeff, thanks for your reply. In the last weeks I was not able to work on this problem. Because I'm on a linux system, I can't use the application builder. Is it possible to automate post processing tasks inside "core" COMSOL? Or do you mean a different kind of app? Thanks Andre
Posted: 9 years ago 3 feb 2016, 14:11 GMT-5
Hi Andre,
Yes, that is the type of app I meant. Any option of emulating Windows on your linux machine? We have customers using the App Builder on Macs using Boot Camp for that same reason.
Hi Andre, Yes, that is the type of app I meant. Any option of emulating Windows on your linux machine? We have customers using the App Builder on Macs using Boot Camp for that same reason. Jeff
Posted: 9 years ago 4 feb 2016, 03:57 GMT-5
Hello Jeff,
thank you for the clarification. I have to check with our IT department about emulating windows.
Bye
Andre
Hello Jeff, thank you for the clarification. I have to check with our IT department about emulating windows. Bye Andre
