Does version 5.0 with matlab contains function like flim2curve and loft command.?
We were using version 3.5a from ling time to make MRI image model segmentations with matlab. now, we are thinking to update version to 5.0 . so I would like to know I it possible to use similar commands in 5.0.
Can i make model from from MRI images in 2d and 3d and also transfer it to comsol ? as i know its not possible in version 4.
with regards
Nitish
4 Replies Last Post 12 giu 2016, 23:41 GMT-4
Remi Magnard COMSOL Employee
Posted: 9 years ago 22 gen 2016, 04:54 GMT-5
Dear Nitisch,
In the current version of LiveLink for MATLAB you can use the function called MPHIMAGE2GEOM to create COMSOL geometry using image data such as MRI.
Dear Nitisch, In the current version of LiveLink for MATLAB you can use the function called MPHIMAGE2GEOM to create COMSOL geometry using image data such as MRI. Best regards,
Posted: 9 years ago 22 gen 2016, 05:21 GMT-5
Dear Mr. Remi Magnard
Thankyou for your response. That's what i am expecting but i have one more elementary enquiry about the loft command. how about to make it in 3D after using mphimage2geom.
Thanks in advance.
Dear Mr. Remi Magnard Thankyou for your response. That's what i am expecting but i have one more elementary enquiry about the loft command. how about to make it in 3D after using mphimage2geom. Thanks in advance.
Posted: 9 years ago 22 gen 2016, 07:29 GMT-5
You can perform loft operation directly from within COMSOL if you have the Design Module. So you can import the MRI Data in COMSOL and then create the 3D geometry using the built-in functionality.
Posted: 9 years ago 12 giu 2016, 23:41 GMT-4
Hello sir,
I have the same problem that I can not plot 3D geometry with mphimage2geom with matlab. I am trying to load a stack of MRI images that to build a 3D structure and COMSOL can create this geometry. Can you share with me how to do that?
Thank you!
Fei
Hello sir, I have the same problem that I can not plot 3D geometry with mphimage2geom with matlab. I am trying to load a stack of MRI images that to build a 3D structure and COMSOL can create this geometry. Can you share with me how to do that? Thank you! Fei
