Energy balance with variable density
Hello everyone,
I am interested in finding the temperature in a system that changes the density in time and I would like to formulate the energy balance using this variable density.
What I have in mind is to use
Cp * d( rho T)/dt = Q
but I find it pretty tricky to implement it in COMSOL, because of the derivative. Does anyone have any experience with this?
Nomenclature: Cp is the specific heat, rho is the density (rho = f(t)), T is the temperature and Q is the heat source in W/m3, which can be any number (just for reference)]
4 Replies Last Post 27 apr 2016, 12:54 GMT-4
Posted: 9 years ago 27 gen 2016, 07:52 GMT-5
Solved it!
One can simply use d(rho*T,t) in the place where you define the temperature as T and it's derivative as Tt.
Thank Thure!
Solved it! One can simply use d(rho*T,t) in the place where you define the temperature as T and it's derivative as Tt. Thank Thure!
Vitul Raj Govindaraju
Posted: 9 years ago 27 apr 2016, 01:39 GMT-4
Hi Paul,
How to set a variable density for one of the phases ? I am using two phase-level set method. Could you please explain ?
Hi Paul, How to set a variable density for one of the phases ? I am using two phase-level set method. Could you please explain ?
Posted: 9 years ago 27 apr 2016, 06:30 GMT-4
It's hard to say, because I don't know how you are implementing the two phase flow. Is it lump model? Or you are using PDE's? Are you building your own equations or are you using a module from COMSOL? If you are using ODE/PDE modules, then you can easily implement the density as d(rho,t) for the specific phase.
Posted: 9 years ago 27 apr 2016, 12:54 GMT-4
Oh, sorry. I misread the question. To set a variable density for a phase, you can set an Interpolation Function (Global Definitions > Functions > Interpolation)
If you know the density as a function of temperature, you can write the temperature in the first column and the density in the second. Then you label the function as rho, for example, and you call it with rho(T) in your governing equations. In this case T is your Temperature variable.
Oh, sorry. I misread the question. To set a variable density for a phase, you can set an Interpolation Function (Global Definitions > Functions > Interpolation) If you know the density as a function of temperature, you can write the temperature in the first column and the density in the second. Then you label the function as rho, for example, and you call it with rho(T) in your governing equations. In this case T is your Temperature variable.
