8 years ago
29 gen 2016, 07:24 GMT-5
Hi Chironjeet,
you can store your time-temperature data in txt file and then import it into COMSOL. You can do this under definitions, then right click and choose function => interpolation. Here you can choose your txt file as input and import it. Here you must also choose a function name for this interpolation (e.g. my_temp). Instead of assigning a constant temperature at a boundary, you do now enter my_temp(t).
Kind regards,
Peter
Hi Chironjeet,
Kind regards,
Peter
8 years ago
29 gen 2016, 07:38 GMT-5
Hallo Peter,
Thank you very much for your suggestion. Can you tell me one more thing, where should i put the unit of time and temperature.
Best Regards,
Chironjeet.
Hallo Peter,
Best Regards,
Chironjeet.
8 years ago
29 gen 2016, 08:56 GMT-5
It is at the bottom under the interpolation node (under units).
KInd regards,
Peter
KInd regards,
Peter
8 years ago
3 feb 2016, 06:32 GMT-5
Hallo Peter,
I have one question to you. May be it's a stupid question but i'm really confused.
I am running transient thermal simulation where i set the time dependent temperature function (interpolated), looks like:
1 297
2 298
236 533
So here final time is 236 second and final temperature is 533 Kelvin. If i put the function in one end of domain as boundary condition and if i select the time dependent study for 30 mins, then how comsol will calculate the temperature distribution over the whole domain for the set function. I mean, should i select 236 second in the time dependent study section? or i can select any time. My aim is to see the temperature distribution over the whole domain according to the function what i set initially, so i want to run the simulation until the final time of my set function.
Can you please give me an explanation which will reduce my confusion.
Thanks in advance.
Hallo Peter,
1 297
2 298
236 533
Thanks in advance.
8 years ago
3 feb 2016, 10:05 GMT-5
I am not sure if I understand your question correctly. If you simulate until 236 seconds, your boundary will take the assigned values during the simulation. If the simulation time extends the 236 seconds, it depends on the extrapolation you chose at the interpolation node. The default seems to be constant, so that your boundary will have a temperature of 533 Kelvin in the interval from 236 seconds to the end of the simulation.
Kind regards,
Peter
Kind regards,
Peter
